04-14-2018 10:33 - edited 04-14-2018 10:34
Hi all,
I'm trying to create a clockface with two screens or "pages". So if the user taps the screen, it changes toggles to the second screen. What is the best way to achieve this functionality?
Would I nest an SVG within the main SVG or have two parallel SVG elements?
Approach 1
<svg class="background"> <g id="time-hr"> <text id="myHour" /> <text id="myMinutes" /> <text id="myDate" /> <text id="myHR" /> </g>
<svg id="score" fill="black">
<rect id="myRect" pointer-events="visible" />
<text id="pctScore" pointer-events="visible" />
</svg>
</svg>
Approach 2
<svg class="background"> <g id="time-hr"> <text id="myHour" /> <text id="myMinutes" /> <text id="myDate" /> <text id="myHR" /> </g> </svg>
</svg>
I tried following the documentation on this page, but I was still unclear on the best way to achieve the tap display event to toggle screens. Hope this makes sense and thanks in advance!
04-16-2018 16:25
04-16-2018 16:25
04-16-2018 16:25
You can something similar here https://community.fitbit.com/t5/SDK-Development/Wanted-example-of-multiple-UI-views-and-back-navigat...
04-16-2018 16:33
04-16-2018 16:33
Here is how I did it:
<svg class="background"> <svg id="clock" display="inline"> //Screen 1
</svg> <svg id="stats" display="none"> <//Screen 2 </svg> <rect id="clickbg" pointer-events="visible"/> </svg>
Then in my main code:
background.onclick = function(evt) { console.log("Click"); if (show == "clock"){ // In Clock -> Switching to Stats show = "stats"; updateStatsData() clockView.style.display = "none"; console.log("stats Loaded"); display.poke() } else if (show == "stats"){ //In Stats -> Switching to Clock show = "clock"; updateClock(); clockView.style.display = "inline";//test } //console.log("Show is " + show); }
This code is from my fairly large KearsargeTime watchface.
