04-14-2018 10:33 - edited 04-14-2018 10:34
Hi all,
I'm trying to create a clockface with two screens or "pages". So if the user taps the screen, it changes toggles to the second screen. What is the best way to achieve this functionality?
Would I nest an SVG within the main SVG or have two parallel SVG elements?
Approach 1
<svg class="background">
<g id="time-hr">
<text id="myHour" />
<text id="myMinutes" />
<text id="myDate" />
<text id="myHR" />
</g>
<svg id="score" fill="black">
<rect id="myRect" pointer-events="visible" />
<text id="pctScore" pointer-events="visible" />
</svg>
</svg>Approach 2
<g id="time-hr">
<text id="myHR" />
</g>
</svg>
</svg>I tried following the documentation on this page, but I was still unclear on the best way to achieve the tap display event to toggle screens. Hope this makes sense and thanks in advance!
Best Answer04-16-2018 16:25
04-16-2018 16:25
04-16-2018 16:25
You can something similar here https://community.fitbit.com/t5/SDK-Development/Wanted-example-of-multiple-UI-views-and-back-navigat...
04-16-2018 16:33
04-16-2018 16:33
Here is how I did it:
<svg id="clock" display="inline">
//Screen 1
</svg>
<svg id="stats" display="none">
<//Screen 2
</svg>
<rect id="clickbg" pointer-events="visible"/>
</svg>Then in my main code:
background.onclick = function(evt) {
console.log("Click");
if (show == "clock"){ // In Clock -> Switching to Stats
show = "stats";
updateStatsData()
clockView.style.display = "none";
console.log("stats Loaded");
display.poke()
} else if (show == "stats"){ //In Stats -> Switching to Clock
show = "clock";
updateClock();
clockView.style.display = "inline";//test
//console.log("Show is " + show);
}This code is from my fairly large KearsargeTime watchface.
