09-01-2023 01:54
09-01-2023 01:54
I'd like to use body presence with BodyPresenceSensor. But I got "null" from "bodyPresence.present". (I just followed official procedure blow.)
How to solve this problem?
Code:
import { BodyPresenceSensor } from "body-presence";
if (appbit.permissions.granted("access_activity")) {
if (BodyPresenceSensor) {
console.log("This device has a BodyPresenceSensor!");
const bodyPresence = new BodyPresenceSensor();
console.log(bodyPresence.present);
bodyPresence.addEventListener("reading", () => {
console.log(`The device is ${bodyPresenceSensor.present ? '' : 'not'} on the user's body.`);
bodyPresence.start();
} else {
console.log("This device does NOT have a BodyPresenceSensor!");
Best Answer09-01-2023 13:27
09-01-2023 13:27
Sorry, I meant the sensor itself. bodyPresence.activated is false initially; until it's activated, .present seems to return null.
Use onactivate if you need a reading ASAP.
Best Answer09-01-2023 01:56
09-01-2023 01:56
This is terminal output when above code was excuted.
fitbit$ bi
> my-first-clock@0.1.0 build C:\Users\xxxx\Documents\fitbit_project\my-first-clock
> fitbit-build
[17:44:37][warn][app] "HeartRateSensor" is imported from external module "heart-rate" but never used in "app/activity.js".
[17:44:37][info][app] Building app for Fitbit Versa 3
[17:44:37][info][app] Building app for Fitbit Sense
[17:44:37][info][companion] Building companion
[17:44:38][info][settings] Building settings
[17:44:38][info][build] App UUID: 043ab4b3-11111-b1e6-bf02c7cc2770, BuildID: 0x0012e94582372848
No app package specified. Reloading ./build/app.fba.
Loaded appID:043ab4b3-11111-b1e6-bf02c7cc2770 buildID:0x0012e94582372848
Sideloading app: 100% completed
App install complete (partial)
Sideloading companion: starting...
[17:44:39] App: Error 22 Invalid attribute 'data-size' in animate-in (mnt/sysassets/widgets_common.gui:301,1)
[17:44:39] App: App Started
Companion install complete (full)
Launching app
[17:44:40] App: App Closed
[17:44:41] App: App Started
[17:44:41] App: This device has a BodyPresenceSensor! (app/activity.js:144,7)
[17:44:41] App: null (app/activity.js:146,7)
[17:44:41] Companion: Hello world! (companion/index.js:1,1)
Device 'Versa 3 Simulator' disconnected
Phone 'Simulator' disconnected
fitbit$
Best Answer09-01-2023 02:24
09-01-2023 02:24
Maybe you need to wait for the sensor to be activated.
(I also suspect that bodyPresenceSensor will cause problems, despite the documentation.)
Best Answer09-01-2023 02:37
09-01-2023 02:37
When development with fitbit OS simulator, should I wait untill it is activated? Is it activated by excuing "npx fitbit" and just waiting?
09-01-2023 13:27
Best Answer09-04-2023 18:17
09-04-2023 18:17
Thank you for giving useful information.
I've tried to use onactivate property and checked the value of "bodyPresence.onactivate". But it returns "undefined" as below.
Did I any mistakes? I'm very happy for you to send sample code (js) to get value of "onactivate" (without "undefined").
Code:
setInterval(() => {
console.log(bodyPresence.onactivate);
}, 2000);
// console.log(bodyPresence.present);
} else {
Terminal output:
> fitbit-build
[10:04:39][warn][app] "HeartRateSensor" is imported from external module "heart-rate" but never used in "app/activity.js".
[10:04:39][info][app] Building app for Fitbit Versa 3
[10:04:40][info][app] Building app for Fitbit Sense
[10:04:40][info][companion] Building companion
[10:04:40][info][settings] Building settings
[10:04:40][info][build] App UUID: 043ab4b3-xxxxx-b1e6-bf02c7cc2770, BuildID: 0x0ae5dc126e9d814d
No app package specified. Using default ./build/app.fba.
Loaded appID:043ab4b3-xxxxx-b1e6-bf02c7cc2770 buildID:0x0ae5dc126e9d814d
App requires a device, connecting...
Auto-connecting only known device: Versa 3 Simulator
App requires a phone, connecting...
Auto-connecting only known phone: Simulator
[10:04:42] App: undefined (app/activity.js:154,20)
[10:04:44] App: undefined (app/activity.js:154,20)
[10:04:45] App: Error 22 Invalid attribute 'data-size' in animate-in (mnt/sysassets/widgets_common.gui:301,1)
[10:04:45] App: App Started
Launching app
[10:04:46] App: App Closed
[10:04:46] App: App Started
[10:04:46] App: This device has a BodyPresenceSensor! (app/activity.js:145,7)
[10:04:47] Companion: Hello world! (companion/index.js:1,1)
[10:04:48] App: undefined (app/activity.js:156,9)
[10:04:50] App: undefined (app/activity.js:156,9)
[10:04:52] App: undefined (app/activity.js:156,9)
[10:04:54] App: undefined (app/activity.js:156,9)
[10:04:56] App: undefined (app/activity.js:156,9)
[10:04:58] App: undefined (app/activity.js:156,9)
[10:05:00] App: undefined (app/activity.js:156,9)
[10:05:02] App: undefined (app/activity.js:156,9)
[10:05:04] App: undefined (app/activity.js:156,9)
(^C again to quit)
fitbit$
Best Answer09-04-2023 19:10
09-04-2023 19:10
onactivate is a property to which you can assign a listener; ie, a function that you write. The system will then call your function when the sensor is activated. You don't need setInterval, and reading the value of onactivate simply returns the currently-assigned listener function (ie, undefined because you haven't assigned a listener).
09-05-2023 19:51
09-05-2023 19:51
I see.
I didn't do well on fitbit OS Simulator, but was able to deployed on real device with following doc.
Thank you for helping me!
Official doc:
