11-10-2018 08:30
11-10-2018 08:30
Hello,
I tried my hands on the fitbit studio connection to the simulator. I tried the blank and other templates but the project wouldn't build or run. It says something like 'internal error: Guru mediattion.' Is not it supposed to build successfully when no changes are made to the template?
* I use mac
* Simulator was using versa
Thanks.
11-10-2018 13:44
11-10-2018 13:44
Can you try using Google Chrome if you're not already. It may be browser specific.
11-10-2018 08:37
11-10-2018 08:37
The blank project is completely empty, but the other projects should build.
Are you seeing this error when clicking "build" or run?
11-10-2018 08:57
11-10-2018 08:57
Yes, when clicking build or run.
11-10-2018 13:44
11-10-2018 13:44
11-11-2018 03:44
11-11-2018 03:44
**ahem**! You are right. Works in Chrome. Sad, it's not in Firefox which is my favorite browser.
Thanks!
11-11-2018 03:52
11-11-2018 03:52
Update: I updated Firefox and it works here too!!
11-11-2018 04:45
11-11-2018 04:45
That's great, thanks for the update.
