I have been doing a lot of searching and have found no answers to this.
All the samples and documentation show the ability to use height, width, x, and y in the styles.css file.
For example what has been shown to work and what I am using:
This is for an image resource referenced in the index.gui file
Best AnswerThis sounds like a problem I had a long time ago that was due to a very subtle typo - i think it as something at the end of a line. I finally found it by cutting out most of the file and adding it back in an element at a time.
Hope this helps.
Best AnswerYes, here is a copy of the widgets.gui file - it is the default one created with a new project.
<svg>
<defs>
<link rel="stylesheet" href="styles.css" />
<link rel="import" href="/mnt/sysassets/widgets_common.gui" />
</defs>
</svg>
Best AnswerIn addition, I copied the whole project up to the web based studio, and had the same issues as I did with the CLI version.
Hope this helps.
Best AnswerStill not sure what caused it, but literally stripped out all unnecessary characters, made it single line, and it started working.
Hopefully this will continue as I do have a formatting standard I like to use.
Thanks Drifty26!!
Best AnswerI did find a specific issue that caused the error!!
I can format the CSS as I had shown, and it worked fine. HOWEVER, if you put space(s) between the +(plus) or -(minus) in the positioning elements, it fails to properly format the text or image on the Fitbit.
