My application is using Restful API's. So if FitBit watch is not connected to Wifi, can it still sync data via bluetooth and my API's will be called successfully?
Your application needs a companion, which runs within the Fitbit mobile app.
https://dev.fitbit.com/build/guides/companion/
Then you can use the messaging API to send a request from the device to the companion, and the companion can perform the fetch()
https://dev.fitbit.com/build/guides/communications/messaging/
