08-29-2018 13:11 - edited 08-29-2018 13:11
My application is using Restful API's. So if FitBit watch is not connected to Wifi, can it still sync data via bluetooth and my API's will be called successfully?
09-01-2018 09:40
09-01-2018 09:40
Your application needs a companion, which runs within the Fitbit mobile app.
https://dev.fitbit.com/build/guides/companion/
Then you can use the messaging API to send a request from the device to the companion, and the companion can perform the fetch()
https://dev.fitbit.com/build/guides/communications/messaging/
Best Answer09-01-2018 09:40
09-01-2018 09:40
