I'm trying to run Fitbit OS Simulator and cannot get it running. Here's what I see in logs.log:
[2018-07-01 11:59:44.553] [info] appsim stdout: [I][11:59:44.175][] Starting breakpad client - reporting to \\.\pipe\Fitbit OS Simulator Crash Service
[D][11:59:44.192][] Scheduler starting dispatch time: 1530439184192
Fb_AlarmMgr_Clean is running[I][11:59:44.553][] Simulator control server starting on 127.0.0.1:63981
[A][11:59:44.553][] Houston, this is Ionic!!
[A][11:59:44.553][] Press ? anytime for help
[A][11:59:44.553][] Version: 255.1.659 (May 24 2018 17:00:32): Fake for tests
[A][11:59:44.553][] GNU_BUILD_ID:
mfgtst $
[2018-07-01 11:59:47.507] [warn] 10 retries left: Error: connect ECONNREFUSED 127.0.0.1:63981
[2018-07-01 11:59:47.508] [warn] 10 retries left: Error: connect ECONNREFUSED 127.0.0.1:63982
[2018-07-01 11:59:49.512] [warn] 9 retries left: Error: connect ECONNREFUSED 127.0.0.1:63981
[2018-07-01 11:59:49.518] [warn] 9 retries left: Error: connect ECONNREFUSED 127.0.0.1:63982
[2018-07-01 11:59:52.517] [warn] 8 retries left: Error: connect ECONNREFUSED 127.0.0.1:63981
[2018-07-01 11:59:52.523] [warn] 8 retries left: Error: connect ECONNREFUSED 127.0.0.1:63982
[2018-07-01 11:59:56.521] [warn] 7 retries left: Error: connect ECONNREFUSED 127.0.0.1:63981
[2018-07-01 11:59:56.528] [warn] 7 retries left: Error: connect ECONNREFUSED 127.0.0.1:63982
[2018-07-01 12:00:01.526] [warn] 6 retries left: Error: connect ECONNREFUSED 127.0.0.1:63981
[2018-07-01 12:00:01.534] [warn] 6 retries left: Error: connect ECONNREFUSED 127.0.0.1:63982
[2018-07-01 12:00:07.536] [warn] 5 retries left: Error: connect ECONNREFUSED 127.0.0.1:63981
[2018-07-01 12:00:07.542] [warn] 5 retries left: Error: connect ECONNREFUSED 127.0.0.1:63982
[2018-07-01 12:00:14.546] [warn] 4 retries left: Error: connect ECONNREFUSED 127.0.0.1:63981
[2018-07-01 12:00:14.549] [warn] 4 retries left: Error: connect ECONNREFUSED 127.0.0.1:63982
[2018-07-01 12:00:22.557] [warn] 3 retries left: Error: connect ECONNREFUSED 127.0.0.1:63981
[2018-07-01 12:00:22.558] [warn] 3 retries left: Error: connect ECONNREFUSED 127.0.0.1:63982
[2018-07-01 12:00:31.576] [warn] 2 retries left: Error: connect ECONNREFUSED 127.0.0.1:63981
[2018-07-01 12:00:31.582] [warn] 2 retries left: Error: connect ECONNREFUSED 127.0.0.1:63982
[2018-07-01 12:00:41.592] [warn] 1 retries left: Error: connect ECONNREFUSED 127.0.0.1:63982
[2018-07-01 12:00:41.593] [warn] 1 retries left: Error: connect ECONNREFUSED 127.0.0.1:63981
Do I miss something obvious here?
Where did you find logs.log?
I had a problem on one laptop where I had to run the simulator as administrator for it to work. But for some reason that doesn't seem to be required any more.
Wouldn't hurt to give it a try.
John
Best AnswerI get that error when my firewall interferes. That's probably not your problem, but may be worth a quick check.
