I am trying to build my first watchface. I have the stats and goals all showing as numbers, but I am trying to now change these into bar graphs.
width=100% = goal reached
width=0% = no progress
I have the rectangle showing on my screen due to the following in my gui file. But I can't seem to find a way to change the rectangle width in my actual index file. Eventually hoping to do this off of a calculation actual/goal.
<rect x="0%" y="57%" width="150" height="25" fill="mediumvioletred" />
Any suggestions are appreciated. I am still learning, so trying to keep it as basic as possible.
Thanks!
Best AnswerI think a problem may be that % measurements only work in .CSS. You'll probably have to use px in .js. You can capture the 100% width in .js when your app starts; that will make it easier to adapt your clockface for different devices.
Best AnswerYou can assign an id to the rect element and then retrieve the element by id in the js file.
For example:
.gui:
<rect width="150" height="25" id="bar1" />
.js:
const bar1 = document.getElementById("bar1");
bar1.width=200;
