I want to get a special edition Charge 3 because it has an NFC chip and I want to start some Arduino projects that read a unique ID (fitbit hardware ID?) or some data from the NFC chip and trigger some actions... if I buy all the hardware I need and a Charge 3, will I be able to scan it and get some data to recognise myself from the fitbit device or is it locked down? For example: I want to get some fitbits at work and let everyone clock-in and clock-out by scanning their fitbit when they enter the office... Is that possible or can you update the API to support that?
I don't want to trigger actions on the fitbit, I want to trigger actions on my own software and hardware.
I just want to know if I hold the Charge 3 over my own NFC reader - will I be able to get a unique ID or some other data from it (MAC address?) or something I can identify the users with? Or will it not register and pick up the fitbit device on my own NFC reader at all?
I just tried it with my Ionic and the NFC reader on my phone and it was able to read the tag.
Best AnswerI would be interested to know if this is possible too! Using the NFC chip for custom applications would be amazing.
I have a charge 3, the special edition with nfc payment option. Not sure if the basic charge 3 will work .
Holding mine to my phone I get a code .
The watch shows as a :
Tag type: ISO 14443-4 NXP MIFARE Plus
Technology available: IsoDep, NfcA
Serial number: 27:5A:B3:27 *note I've changed that but you can see the format
HOWEVER .. Each time you scan the fitbit you get a different number So it looks like it's an encrypted rolling code.. That means I don't think you'll be able to use it to identify someone. Bugger That's what I wanted to to with it too
Anyone else has any luck with something like this ?
