Hi, is it possible to find and download any example of clockface design for Fitbit Charge 6?
I have installed the Fitbit Simulator, but this device type is not available yet. When do you expect to include it?
Thank you
Best AnswerWhy not provide another way to create custom designs?
I miss some designs from Charge 4. Charge 6 looks very colorful, but all designs with big numbers are misaligned or number cut, none are easier to read as before and none have seconds.
If I can't design my own clockface, I would appreciate if you could recover some of the old layouts, personally, the one with the digital numbers in the center and analog seconds around it, with the date and dynamic data.
Also, it would be helpful if you could customize all clockface colors as you can do with the Fast line design.
I recommend that you post your suggestions in the Product Feedback section, since they are not about SDK development.
