03-01-2018 23:55
03-01-2018 23:55
Is there a checkbox component that I can use in my application? The fitbit alarm app has one but i'm not sure if it just undocumented like the Tumbler component or just a custom control of the app.
Best Answer03-02-2018 10:32
03-02-2018 10:32
Sorry we're falling short in the documentation, we'll have more soon!
I hope this helps:
<!-- widgets.gui -->
<svg>
<defs>
<link rel="stylesheet" href="styles.css" />
<link rel="import" href="/mnt/sysassets/widgets_common.gui" />
<!-- Additional imports -->
<link rel="import" href="/mnt/sysassets/widgets/tile_list_widget.gui" />
<link rel="import" href="/mnt/sysassets/widgets/checkbox_tile_widget.gui" />
<!-- Custom tile list item with checkbox -->
<symbol id='log-checkbox-tile' href='#tile-list-item'>
<use id="log-checkbox" href='#checkbox-tile'/>
</symbol>
</defs>
</svg>
<!-- index.gui -->
<svg> <use id="my-list" href="#tile-list" class="application-color"> <!-- specify how many pixels of the content are taken by separators --> <var id="separator-height-bottom" value="2"/> <!-- disable tile list reordering --> <var id="reorder-enabled" value="0"/> <use id="log1" href="#log-checkbox-tile" class="tile"> <set href="log-checkbox/header/text" attributeName="text-buffer" to="Log 1" /> </use> <use id="log2" href="#log-checkbox-tile" class="tile"> <set href="log-checkbox/header/text" attributeName="text-buffer" to="Log 2" /> </use> <use id="log3" href="#log-checkbox-tile" class="tile"> <set href="log-checkbox/header/text" attributeName="text-buffer" to="Log 3" /> </use> </use> </svg>
// app/index.js
import document from "document";
let list = document.getElementById("my-list");
let tiles = list.getElementsByClassName("tile");
// manually track the checked state
let mystate = {}
tiles.forEach((element, index) => {
element.firstChild.onclick = (evt) => {
mystate[index] = !mystate[index];
console.log(`item ${index} checked = ${mystate[index]}`)
03-02-2018 01:14
03-02-2018 01:14
We are still awaiting quite a bit of documentation.
Maybe @JonFitbit would post some examples as he so kindly did for the other components ![]()
03-02-2018 10:32
I hope this helps:
<svg>
<defs>
</symbol>
</defs>
</svg>
<!-- index.gui -->
// app/index.js
let mystate = {}
05-12-2018 14:14
05-12-2018 14:14
Hi :), can the checkbox component be used inside other components such as a panoramaview?
12-13-2022 11:24
12-13-2022 11:24
Hi Jon! Does this checkbox still work for Sense 2 devices? I tried it in my clockface for Sense2, but it does not seem work do anything. Nothing appears on the UI.
Best Answer12-13-2022 15:27
12-13-2022 15:27
@barbossaNot until an SDK for Sense 2 is released. A date hasn't been set for that.
