Docs here: https://dev.fitbit.com/build/reference/device-api/display/
You could hook up to the onchange event.
Set a timer to poke() to extend the timeout maybe? Not tested it but at least a thought ....
Best AnswerMaybe possible with: https://dev.fitbit.com/build/reference/device-api/display/ and an timer?
Edit: to slow 😞
Best AnswerDoes display.autoOff not work for watch faces? I've used it successfully in an app.
The only differences with apps and clocks are:
1. Clocks cannot use buttons.
2. You can only have 1 clock installed.
Everything else is the same.
