12-05-2017 09:39
12-05-2017 09:39
I am using Combo button inside an svg hierarchy so I cannot use use onactivate event because it does not fire.
It looks like a well known bug.
square-buttons-sometimes-no-action
I am using onclick as workaround and it is working fine but I have noticed that the Combo button is not linked anymore with the nearest physical button.
How can fix this issue?
How can I trigger an action when right-up or right-down physical buttons are pressed?
I've already tried to use document.onkeypress event but it does not fire when right-up or right-down are pressed. It fires properly only when back button is pressed.
01-28-2018 06:52
01-28-2018 06:52
Same for me. Anyone got this working?
Best Answer01-28-2018 07:48
01-28-2018 07:48
I had a similar challenge. Check out this thread .... everything you need is there ...
https://community.fitbit.com/t5/SDK-Development/Physical-Button-Exit-App/m-p/2375320
01-30-2018 12:16 - edited 01-30-2018 12:16
Mhm. In my case only the back key is fired as an event. Never got a down or up for the right buttons 😞
01-30-2018 12:39
01-30-2018 12:39
Can you post up your document.onkeypress code?
Best Answer01-30-2018 12:47
01-30-2018 12:47
At the moment it is only:
document.onkeypress = function(e) {
console.log(e.key);
Maybe the reason is the views library of @gaperton causing the problem!? Will check is with a "naked" app
Best Answer01-30-2018 12:53 - edited 01-30-2018 12:53
Yes in a naked app without content there is no problems with the keypress event. It is fired and handled. Didn't get why this is a problem in a more complex app with more markup and views
@gaperton Maybe you can support?
Best Answer01-30-2018 13:08
01-30-2018 13:08
I am using Ionic Views and have it working .....
In your application class you should have
onMount(){
document.onkeypress = this.onKeyPress;
onKeyPress = e => { e.preventDefault(); if( e.key === 'up' ) { console.log("Up"); } if( e.key === 'down' ){
console.log("Down"); } if( e.key === 'back') { console.log("Down");
this.unmount();
me.exit();
Hope the above helps.
01-30-2018 15:53
01-30-2018 15:53
@SunsetRunner gave the right answer. Yes, you should do all the initialization stuff inside of the appropriate `onMount()` method (Application's in this case).
Here's how the same code in my Velocity app looks like. LoadingScreen calls its callback when the GPS is connected, and then you can switch between two screens.
class Velocity extends Application {
radar = new RadarScreen();
history = new HistoryScreen();
onMount(){
this.screen = new LoadingScreen(() => {
gpsData.onChange = () => this.render();
document.onkeypress = this.switchScreens;
Application.switchTo( 'radar' );
switchScreens = ({ key }) => {
if( key === 'down'){
this.screen = this.screen === this.radar ? this.history : this.radar;
Velocity.start();
Best Answer06-18-2018 15:36
06-18-2018 15:36
The answers are not very helpful.
Ive tried everything around onkeypress until i was sick of it.
small workaround that works nicely:
this._btnDone.onkeydown = function(evt){
me.exit();
var exitApp = function(){ me.exit() };
//triggered when physical button clicked
exitApp()
}//triggered when combo button clicked
this._btnDone.onclick = function(evt){
exitApp()
I hope this helps anyone who is having a hard time around this event.
12-31-2018 00:40
12-31-2018 00:40
I noticed that combo buttons have issue with getting triggered along with with physical buttons clicks when I had displayed combo buttons on few screens and not on others. While the combo buttons were included in a svg which was being hidden using svgScreenName.style.display="none", the problem started occurring. I simply moved the buttons outside and used buttonName.visibility="hidden" to hide these buttons and then I am no longer facing this issue. You can see related source code at https://github.com/gurumukhi/fitbit-yoga-app/blob/master/app/index.js
