12-31-2018 08:05
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
12-31-2018 08:05
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
So I'm a bit new to Typescript dev, and struggling a bit with defining and using class files from other .ts files.
I have a app that was working well, but didn't find time to work on it during the year, but now that I have some again and wanted to continue, I was greeted by an error when attempting to build. The error was
TS7009: 'new' expression, whose target lacks a construct signature, implicitly has an 'any' type.
The lines responsible for this in the index.ts file are:
import { Engine } from "./src/tamaController"; let engine = new Engine();
And the snippet from the file i'm attempting to import was:
export function Engine() { // code here.. }
At first, I had the .ts extension on my import statement, which resulted in my first error when returning to dev on this project. Apparently, you can no longer import files and supply the .ts extension?
I've tried to change the code in the tamaController.ts file to:
export class Engine { constructor() { //.. } testFunction() { console.log("Test"); } }
But that failed because "Cannot find name 'console'." and I'm pretty sure for debugging I used to use console.log in my apps.
I've also noticed, if I try to do:
import clock from "clock";
At the top of my tamaController.ts file containing my class, it fails with the same error as console above:
TS2307: Cannot find module 'clock'.
Not sure what would be the correct way to work with objects in TS for Fitbit, or if what I tried with the export class is correct, you just need to require the API imports from Fitbit differently in those files.
Accepted Solutions
12-31-2018 08:37
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
12-31-2018 08:37
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Ok, so this is not perfect, but I got it to work at least
In my index.ts I have
import clock from "clock"; import { Engine } from "./src/tamaController"; let engine = new Engine(clock, console); engine.testFunction();
And in my tamaController.ts I have:
export class Engine { console: any constructor(clock: any, console: any) { this.console = console; clock.granularity = "minutes"; } testFunction() { this.console.log("Test"); } }
The clock part is just there so that it doesn't build empty and error, but hopefully acts as a example for others
I'm marking this as the solution, but still not happy passing all the imports like that since my app will have many imports...
12-31-2018 08:31
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
12-31-2018 08:31
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
Just a small update, to try and get past the unable to import part, I tried the following
In my index.ts
let engine = new Engine(clock);
clock: Object
constructor(clock: Object) {
this.clock = clock;
testFunction() {
this.clock.granularity = "minutes";
But this fails with
TS2339: Property 'granularity' does not exist on type 'Object'.
So my idea of passing it seems to not work either 😞
12-31-2018 08:37
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
12-31-2018 08:37
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Report this post
