Hi all -
I'm getting some unintended behavior from my app. I have a combo button that sets my "main" screen to hidden and sets my "menu" screen to visible. I also have the following code to navigate back to my "main" screen. After I go back, the combo buttons on my "main" screen no longer trigger the events they're supposed to.
Can you guys see anything wrong with my code here?
document.onkeypress = function(evt) {
if (evt.key === "back") {
if (document.getElementById("menu").style.visibility === "visible") {
// Go to screen 2
evt.preventDefault();
showMain();
} else if (document.getElementById("main").style.visibility === "visible") {
// Default behaviour to exit the app
function showMenu() {
console.log("Show menu");
document.getElementById("main").style.visibility = "hidden";
document.getElementById("menu").style.visibility = "visible";
function showMain() {
console.log("Show main");
document.getElementById("main").style.visibility = "visible";
document.getElementById("menu").style.visibility = "hidden";
I'd probably make a few changes and add some logging to see what's happening:
let main = document.getElementById("main");
let menu = document.getElementById("menu");
console.log(`Main is: ${main.style.visibility}`);
console.log(`Menu is: ${menu.style.visibility}`);
if (menu.style.visibility === "visible") {
// Go to screen 2
showMain();
} else if (main.style.visibility === "visible") {
main.style.visibility = "hidden";
menu.style.visibility = "visible";
main.style.visibility = "visible";
menu.style.visibility = "hidden";
