06-21-2018 17:21
06-21-2018 17:21
I am stepping thru creating my first new Clockface per the "Getting Started" SDK guide.
On the watch, though, when I go into Options->DeveloperBridge, and try to connect to Fitbit Studio, I always get a connection error.
When looking at the watch thru Versa->About, I do see an IP address on the watch
I have tried many steps to fix this
I have tried toggling the following Fitbit Phone App settings
All without luck
I am stuck. I don't know what else to try. I cannot run the new clockface on my Versa watch from Fitbit Studio. I tried following a similar Forum message on this same "1006 Error" topic, but it did not help
Thanks . . . Leigh Potter
06-22-2018 02:33
06-22-2018 02:33
I'm having the same issue.
Phone can connect, but the Fit bit Versa continually fails.
I've tried using the Android hotspot and work WiFi, tried restarting the watch, nothing has worked
firmware is 32.32.10.15
06-22-2018 05:34
06-22-2018 05:34
Same problem here, got my Versa a few days ago and it connected successfully the first times but today it keeps getting error 1006 when trying to bring up the dev bridge.
I've dumped the network activity from the watch and after it connects to Wifi it makes a DNS query for 032-v3-client.fitbit.com and makes an HTTPS request to 169.55.193.23, after that it closes the HTTPS connection, disconnects Wifi and restarts the cycle for 4-5 times before showing the error 1006 message.
In other words the network works fine and the problem seems to be with the fitbit server.
06-22-2018 20:09
06-22-2018 20:09
I didn't change anything . . . but this seems to work fine today
Best Answer06-22-2018 20:32
06-22-2018 20:32
Just checked mysef and it connected straight away .
The server must have been having some issues 🙃
Best Answer04-26-2019 11:01 - edited 04-26-2019 11:12
Nearly the same problem, my laptop can connect, but my Fitbit Versa SE just can't be found
Version is 32.33.1.30
Best Answer06-07-2020 14:23
06-07-2020 14:23
yeh I got. the same problem, my phone can connect but my versa 2 does the exact same thing
08-09-2020 08:44
08-09-2020 08:44
Sad but true. You would think they would want us developers making cool apps for it so they could sell more watches. But they can't seem to keep their developer server up (Connection error 1006), so we give up on writing apps.
