04-07-2022 03:21
04-07-2022 03:21
Connecting to developer bridge gives an connection error 1006 after the connection drops for 3 times straight. The simulator works and connects perfectly to the device.
Is this due to the new SSL Certificates that SDK 6.1.0 mentioned which drops the connection?
04-11-2022 03:47
04-11-2022 03:47
Turns out the watch wasn't connecting to my wifi properly, so I removed the wifi and reconnected it back again. All working now 😄
04-07-2022 03:58
04-07-2022 03:58
Just make sure the device is sufficiently charge (above 25%) and reboot the device. The certificate problem only affected the simulator.
Best Answer04-07-2022 13:29 - edited 04-07-2022 17:52
The connection to the server keeps dropping every time, which forces it to reconnect to wi-fi after disconnecting and so on which is really annoying. I tried using my hotspot which it also fails to connect.
Best Answer04-11-2022 03:47
04-11-2022 03:47
