01-18-2022 12:22
01-18-2022 12:22
Fitbit studio can barely keep connected for 10 minutes. As soon as a file is edited an obnoxious popup stops you doing any more work. Connection is perfect, never had any issues on any other site, just Fitbit can't program properly and relies on people to use software which disconnects you every time you make a change
Never has an error popup had such an accurate title
This happens every edit, and is unavoidable. Makes developing apps impossible
01-18-2022 12:46
01-18-2022 12:46
I'm having the same issues. Fitbit must be having server issues.. I can't even get the Weather info to load on my watch.
[3:43:35 PM]loadData() failed. Error: Couldn't find file: /private/data/weather.cborapp/newfile.js:30,5
[3:43:35 PM]loadData() failed. Error: Couldn't find file: /private/data/weather.cborapp/newfile.js:37,5
[3:43:35 PM]No data found
[3:43:35 PM]No data found.
