I have uploaded a number of PNGs to the resources folder for use in my app. They are working fine.
Now I would like to use them as the icon in a <TextImageRow>. This (https://community.fitbit.com/t5/SDK-Development/Settings-Select-with-TextImageRow/td-p/3607886) doesn't address my issue as the icon property of TextImageRow expects a URL not a local file reference.
This (https://community.fitbit.com/t5/SDK-Development/Can-I-use-TextImageRow-with-a-local-asset/m-p/228564...) seems to suggest a workable option. However, I would prefer to generate the icon data through the app, not hardcode it into the app (allowing for easier image changes).
I have tried creating a <canvas> (so that I could use https://developer.mozilla.org/en-US/docs/Web/API/HTMLCanvasElement/toDataURL) but document.createElement() doesn't appear to work on the fitbit platform.
I've also tried using FileReader (https://stackoverflow.com/a/58952747/999430) but FileReader doesn't appear to be resolvable on the fitbit platform.
What should my next step be or is this simply not possible?
Best AnswerIt may be possible. If you can get your images into SettingsStorage, they'll be saved in there as Base64. I think you can then refer to that data when populating yourTextImageRows.
In general, bear in mind that the watch doesn't have an HTML DOM and doesn't have a browser, so off-the-shelf solutions that work in other environments may not apply here.
