I made a clock facet where you can see the battery levels as an icon. I wanted to make the battery icon show when its charging. The problem is that there's a Fitbit default charging indicator that is floating on top of my battery indicator when I start to charge.
Is there a way to hide or override the default behavior?
Maybe this is to simple of an approach, but if you only want your battery icon to show when it is charging, why fight the default set by Fitbit? Couldn't you hide your percentage when it is charging and then show it when its not?
Best AnswerI wanted the charging indicator to have the same style as the battery indicator to make it more stylish.
Best AnswerAs Catplace has already pointed out, there is no way to override the behavior. Think about changing your battery icon to match the size and position of the default behavior. It would then appear more seamless to the end user....
