01-23-2019 00:51
01-23-2019 00:51
Is there any documentation about the `repl device` command available inside the CLI?
repl device Enter into a REPL with the connected device
I was not able to find any clues by using `fitbit$ repl$ console.log(Object.keys(this))`
Thanks!
Best Answer01-23-2019 05:52
01-23-2019 05:52
Is there an example on how to do that?
It looks like import is not available, but I can use 'require'... so I am good to go. Thanks!
fitbit$ repl device Entering REPL mode, type "exit" to quit
fitbit$ repl$ var document = require('document')
undefined
fitbit$ repl$ document.getElementById('vibration-list')
[object Object]
fitbit$ repl$ var vibration = require('haptics').vibration
01-23-2019 02:43
01-23-2019 02:43
At this time, I beleive it only works with the simulator. But the device version should ship in the next firmware update.
Best Answer01-23-2019 04:25
01-23-2019 04:25
Thanks!
Yes, it only works with the simulator...but how can it be used?
What can one do with the REPL.
Best Answer01-23-2019 05:00
01-23-2019 05:00
You should be able to move elements around on screen, update colors, change variables etc, without having to reinstall the app.
01-23-2019 05:52
01-23-2019 05:52
undefined
[object Object]
01-23-2019 05:56
01-23-2019 05:56
Those really should be imported in your app already during the build process. repl should be used for manipulating the existing app, not development of the app.
Best Answer01-23-2019 06:48
01-23-2019 06:48
Thanks for the info.
For some reason, I don't have the app objects loaded in the repl... this is why at first I was not sure if repl is functional.
Best Answer01-31-2019 10:41
01-31-2019 10:41
They'll be there, but not under the names you might expect. When you build your app, the code gets minified using Terser, and a function name like "myAwesomeFunc" gets mangled into "a" to save memory.
02-01-2019 13:46
02-01-2019 13:46
What I also find usefully is to check an existence of certain JS functions. Sometimes I forget that device supports the ES5 syntax only. So there is on implementation of Object.values for instance. So one of the usageu example is a quick check if your function will work or not.
Best Answer02-01-2019 15:11
02-01-2019 15:11
Is there a way to disable name mangling ?
or is there a source map?
How are we supposed to use the repl and for which tasks ? 🙂
Thanks!
Best Answer02-01-2019 15:22 - edited 02-01-2019 15:23
I think the source maps are in your app.fba, which is just a .zip file. Look for *.js.map files. They look like JSON to me. I haven't fully reverse-engineered them, but they don't look too cryptic.
The minification is probably done by an open-source tool for which online documentation exists. More clues may be available here.
