11-12-2021 08:38
11-12-2021 08:38
I have a Fitbit ionic and I am having trouble connecting to the developer bridge and wifi network in my Fitbit app on my home network. I can clearly see the phone is connected to the network but when I go to connect to the Fitbit app wifi to my wifi I can't see the network. When I go to connect the phone to the developer bridge it connects just fine but when I try the Fitbit Ionic it won't show up anymore on the device list. Any suggestions?
Best Answer11-13-2021 07:14
11-13-2021 07:14
I recently had trouble connecting to the developer bridge at home. I was wondering if this has anything to do with the wifi connection in the app and if so my wifi settings won't show up in the app. Has anyone else had this trouble?
Best Answer11-13-2021 07:42
11-13-2021 07:42
Your posts were merged and this is where you need to post for developer assistance. If someone has advice for you, they will post.
Best Answer11-14-2021 23:24
11-15-2021 05:28
11-15-2021 05:28
There's a problem with the simulator at the moment. You can try this workaround, or use a real device. https://community.fitbit.com/t5/SDK-Development/Simulator-SSL-Problem/m-p/5003314#M16156
11-15-2021 05:33
11-15-2021 05:33
Hi @JonFitbit - what is the solution for Firefox?
Best Answer11-15-2021 06:22
11-15-2021 06:22
HI @JonFitbit - as Fitbit Studio also isn't currently working nor is OS simulator.
Best Answer11-15-2021 07:00
11-15-2021 07:00
Hi, @JonFitbit - Is there a way to get a fix for both Fitbit Studio and the OS Simulator via a new version? Currently can't test any changes.
Best Answer11-15-2021 07:05
11-15-2021 07:05
I'm not aware of any issues affecting Studio, just the simulator which you can use the workaround for, or a real device.
11-15-2021 07:11
11-15-2021 07:11
@JonFitbit- Fitbit Studio stuck in perpetual "Here we go checking login.."
Best Answer11-15-2021 07:13
11-15-2021 07:13
Not seeing that here. Can you make a new thread with the details. Which OS and browser, if there are any error messages in the developer console.
Thanks
11-15-2021 07:23
11-15-2021 07:23
@JonFitbit- fixed Studio - you are right not a general issue - had to delete cache data for the Firefox browser itself. Something odd happened when it asked for cookies.
Best Answer11-15-2021 07:31
11-15-2021 07:31
Thanks for getting back, as Studio is fixed, can use a real watch instead of the Simulator.
What exactly is the work around for the Simulator [I'm not using chrome]? or will you be releasing a new version of the Simulator with a fix soon?
Best Answer11-15-2021 07:45
11-15-2021 07:45
The simulator workaround is just to copy the updated certificate to the correct location. https://community.fitbit.com/t5/SDK-Development/Simulator-SSL-Problem/m-p/5003314
We're still trying to get an updated version of the simulator, but there's an issue which is blocking this at the moment.
11-15-2021 09:50
11-15-2021 09:50
Thanks Jon, for the info and transparency, appreciated.
Could you please mention a bit more how to go about copying the certificate on a Windows 10 PC with Firefox as the main browser.
I get a 404 when accessing the site mentioned, so where does one get the certificate and where does one put it that makes the OS Simulator happy?
Best Answer11-15-2021 10:14
11-15-2021 10:14
I marked the post as a the best answer. https://community.fitbit.com/t5/SDK-Development/Simulator-SSL-Problem/m-p/5003314#M16148
11-15-2021 10:29
11-15-2021 10:29
Many thanks @JonFitbit , missed that bit, it works.
