Developer bridge ?
ANSWERED
I'm making my own clockfaces and apps.
Just updated my versa to the latest firmware.
My fitbit versa does not have a 'developer bridge' option anymore . Also the Android app does not show a 'developer menu' option. What do I do wrong?
1 BEST ANSWER
Accepted Solutions
That's unusual. The developer menu appears once you'd accepted the developer terms and conditions. Log into studio.fitbit.com with the Fitbit account which your device is linked with, then the option should appear once you've accepted the terms, and sync'd your device.
3 REPLIES 3
I accepted the terms and services in studio with the same account, but the option did not appear for me on my phone or device (Inspire HR). Do I need to restart them?
I could be wrong, but I thought the SDK did not support the Inspire.  Could that be the issue?  On further exploration, it seems that it is compatible with the WebAPI, but not the SDK directly which means there is a good chance you will not be able to get the developer bridge to connect.
