02-21-2024 05:46
02-21-2024 05:46
I am so excited with the new feature of stress management in Sense 2. I am wondering whether it is possible to use the Stress data from Fitbit devices to my mobile app. Something like my app will be run when I am too stressful.
Best Answer02-21-2024 11:15
02-21-2024 11:15
Unfortunately the new data isn't exposed in any Fitbit API. In addition, there isn't a public SDK that supports Sense 2.
Best Answer02-21-2024 14:49
02-21-2024 14:49
Thanks @Gondwana
Does it mean that there is no way to build any third party app (no matter watch app ot mobile phone app) for my sense 2 so far? It sounds very sad..
Best Answer02-21-2024 17:28
02-21-2024 17:28
Mobile phone app: you definitely can, using the Web API. Bear in mind that's not real-time and doesn't provide all possible data (but neither does any API).
Watch app: it may be possible using a beta SDK, but that might not allow it to be published to the Gallery.
But yes: the status quo is a bit sad.
Best Answer02-23-2024 08:09
02-23-2024 08:09
@Gondwana Thank you so much for your kindly help. Probably I will try Web API and try to estimate the stress data using available data.
