Displaying batteryLevel on watchface
ANSWERED
I want to Display batteryLevel on watchface.
I referred "https://dev.fitbit.com/build/reference/device-api/power/#".
But I can't it.
"undefined" on  my Console.
Is there a way to do it?
1 BEST ANSWER
Accepted Solutions
In order to use that you need to do the following:
import { battery } from "power";
myBatteryLabel.text = battery.chargeLevel;
I hope this helps 🙂
Barry Michael Doyle
5 REPLIES 5
I hope this helps 🙂
Barry Michael Doyle
Have you put an appropriately named label in your svg? The example uses myBatteryLabel as a label id.
Sorry, I have very easy miss.
Variable name is "battery" to display batteryLevel.
So I changed this variable name, I'm successful!
Thank you so much!
Yes this as just an example of the relevant code. It's the same way you
would set the text of time.
Barry Michael Doyle
So glad you found it 🙂 It's a pleasure! Always great to help each other
😄 This forum is great!
Barry Michael Doyle
