Hi Fitbit,
Just reporting some more broken documentation.
On page : https://dev.fitbit.com/guides/design-guidelines/ui-components/
The links under "Components" on the left are broken.
Kind Regards,
Matthew
Thanks. That is an old page which should have been removed. The correct links are here: https://dev.fitbit.com/build/guides/design-guidelines/
I will get the site updated.
Thanks Jon
