06-24-2018 05:22
06-24-2018 05:22
Ok so:
https://dev.fitbit.com/build/guides/user-interface/svg/
Dynamic Text Area: " you change the text content, the element height will automatically re-adjust."
This is false. I have created a Dynamic text element and when I change the text via:
document.getElementById('text').text="Some text"
The height stays the same as whatever it was before. I have tested this with varying amounts of text. The height never changes.
Is there a way to "refresh" or "reload" the dynamic text area so that it operates as advertised?
06-29-2018 15:34
06-29-2018 15:34
It seems like you need to set the `text-length` attribute to a value large enough for the string.
.someTextField { text-length: 1024 }
or
<text text-length="1024" />
06-29-2018 15:45
06-29-2018 15:45
The issue may be related to this. For a giggle, try turning off the display after you've changed the text, and then turn it back on (letting auto-off do its thing should be sufficient). See if that results in a layout update.
07-18-2022 17:22
07-18-2022 17:22
Since the post is more than four years old I wonder if the issue still hasn't been fixed?
I am developing on a Fitbit Sense using the SDK 6.1.0 and following https://dev.fitbit.com/build/guides/user-interface/svg/#dynamic-textarea
I have still have the same problem that the textarea is NOT resized after changing its text from JS.
Is there a workaround?
