12-28-2017 16:25
12-28-2017 16:25
I'm trying to animate an <arc> element and I'd like for one or more of the attributes of the child <animate> element to be dynamically set in my JavaScript code.
I tried giving the <animate> element an id="animation", referencing it using
let animation = document.getElementById("animation");
and later trying to set an attribute like this:
animation.to = 100;
for example, but it didn't work. I didn't get any runtime errors so I don't really know what's going on.
Any help would be appreciated, thanks.
01-02-2018 12:58 - edited 01-02-2018 12:59
I decided to use the requestAnimationFrame() function to create a loop and animate the arcs in code by updating their sweep-angle each frame according to an easing function. It seems to work well, so that's what I'd recommend to others trying to achieve something similar.
12-29-2017 11:39
12-29-2017 11:39
The animation syntax is different in JavaScript than from the SVG. It's a bit hard to tell what to change without seeing more code, so please refer yourself to animations guide.
12-29-2017 18:12 - edited 12-29-2017 18:14
Basically what I'm trying to accomplish is having an arc animate from 0 degrees to a specific angle that will be determined by some user data. I've read the Animations Guide several times but didn't see anything about controlling attributes of an <animate> element using JavaScript. I did see this which might suit my needs better, but I wasn't sure if it was the only way to achieve my goal.
12-31-2017 18:05 - edited 12-31-2017 18:05
I am having the same issue where I can collect the element by id, but cannot access any of the attributes using basic js functionality.
12-31-2017 18:12
12-31-2017 18:12
I was trying to do this as well, but couldn't get it to work. It seems that the animation elements aren't 'real': I couldn't even read their attributes that were set in the SVG.
IIRC, Microsoft's WPF was a bit like this: the animation bits didn't behave like the other bits. It wouldn't surprise me if Fitbit's implementation is equivalent.
07-25-2018 13:51
07-25-2018 13:51
I am running into this problem as well but I don't quite understand your solution, do you think you could explain it a little further?
07-26-2018 23:13
07-26-2018 23:13
This explains it a bit: https://dev.fitbit.com/build/reference/device-api/globals/
Then in my index.js I just have this:
function updateArcs() { sm.currState.update(); requestAnimationFrame(updateArcs); }
So it calls the update function on the current state every frame, which modifies the arcs' sweep angles among other things.
03-29-2019 16:15
03-29-2019 16:15
Hi,
I've figured out it wihtout having to use requestAnimationFrame
in your index.gui's symbol:
give the <animate> an ID as well
<symbol id="progress"> <arc id="arc" class="arc" start-angle="0" sweep-angle="360"> <animate id="anim" attributeName="sweep-angle" begin="enable" from="0" to="360" dur="2" final="keep" easing="ease-in-out" /> </arc> </symbol>
then as normal, give the <use> an id as well so you can grab it in the code
<use id="arc-minutes" href="#progress" />
grab the elements like this: (see how you can grab the animation element as well as the arc)
const minutesContainer = document.getElementById("arc-minutes"); const minutesAnim = minutesContainer.getElementById("anim"); const minutesArc = minutesContainer.getElementById("arc");
Now you can easily update the "to" attribute and kick off the animation and that's it!
minutesAnim.to = util.calcArc(mins, 60); minutesContainer.animate("enable");
here's my calcArc function in case anyone was interested
function calcArc(current, steps) { let angle = (360 / steps) * current; return angle > 360 ? 360 : angle; }
