03-30-2019 04:18
03-30-2019 04:18
Hello, I am new here. this is probably really simple to the boffins here, but I need help to figure this out.
I would like to set the x coord of a rectangle to a variable.
In app.index.js I calculate and get myRectX which has a numerical value
then in index.gui I have the rectangle
<rect x="myRectX" y="138" width="100%" height="35" fill="fb-black" />
I can't figure out the correct code to use to set the x coord to my variable.
Help appreciated,
Thanks.
03-30-2019 05:21 - edited 03-30-2019 05:24
You have to do it the other way round. First you have to give your rect an id:
<rect id="myRect" x="0" y="138" width="20" height="35" fill="fb-black" />
The coodinates within this definitions should be constant (0 and 138 in the above example)
Second you can access your rect via the id in your javascript code:
import document from "document";
const myRect = document.getElementById("myRect");
Now you can change the coordinates:
myRect.x = 5;
myRect.y = anyOtherVariable;
You can also change the size:
myRect.height = 25;
myRect.width = 70;
And you can change the fill:
myRect.style.fill = "red";
Hope this helps.
Best
Uwe
myRect.x = 5;
myRect.height = 25;
myRect.width = 70;
Hope this helps.
Best
Uwe
03-30-2019 05:35
03-30-2019 05:35
thank you! that worked!
