05-19-2019 08:52 - edited 05-19-2019 08:53
Hello
While developing a watchface, I found out that the declaration of const variables is not enforced later on.
For example:
const foo = "foo"; foo = "bar"; console.log(foo);
Will print "bar" (since the declaration is transpiled to "var foo")
I'm not familiar enough with the Javascript ecosystem.
Is there a way to enforce a syntax check during the build?
Best Answer05-20-2019 11:53 - edited 05-20-2019 11:54
Found out a solution that is working for my particular case:
module.exports = {
"env": {
"browser": true,
"es6": true
"extends": "eslint:recommended",
"globals": {
"parserOptions": {
"ecmaVersion": 2018,
"sourceType": "module"
"rules": {
"no-console": "off",
// unused vars should be stripped by the transpile step
"no-unused-vars": "warn",
Best Answer07-20-2019 05:17
07-20-2019 05:17
The watch only supports ES5, which predates const being added to JavaScript. If you use const in companion/settings, it'll behave as you expect.
In the future, we might be able to detect at compile time with the help of TypeScript when you've attempted to modify a const value.
