Using the basic template code for Settings. Wanting simple integration of changeable text. Despite many small changes still returning [object Object] or error message. Is it the template that needs changing, or is a problem with my code?. Thanks.
app/index.js
import document from "document";
import * as messaging from "messaging";
let One = document.getElementById("One");
let OneL = document.getElementById("P1Subj");
// Message is received
messaging.peerSocket.onmessage = evt => {
console.log(`App received: ${JSON.stringify(evt)}`);
if (evt.data.key === "color" && evt.data.newValue) {
let color = JSON.parse(evt.data.newValue);
console.log(`Setting background color: ${color}`);
One.style.fill = color;
if (evt.data.key === "P1Lesson" && evt.data.newValue) {
let P1LE = JSON.parse(evt.data.newValue);
console.log(`Setting text: ${P1LE}`);
console.log(evt);
OneL.text = P1LE;
// Message socket opens
messaging.peerSocket.onopen = () => {
console.log("App Socket Open");
// Message socket closes
messaging.peerSocket.onclose = () => {
console.log("App Socket Closed");
};companion/index.js
import { settingsStorage } from "settings";
console.log("Companion Socket Open");
restoreSettings();
console.log("Companion Socket Closed");
// A user changes settings
settingsStorage.onchange = evt => {
let data = {
key: evt.key,
newValue: evt.newValue
sendVal(data);
// Restore any previously saved settings and send to the device
function restoreSettings() {
for (let index = 0; index < settingsStorage.length; index++) {
let key = settingsStorage.key(index);
if (key) {
let data = {
key: key,
newValue: settingsStorage.getItem(key)
sendVal(data);
// Send data to device using Messaging API
function sendVal(data) {
if (messaging.peerSocket.readyState === messaging.peerSocket.OPEN) {
messaging.peerSocket.send(data);
}settings/index.jsx
function mySettings(props) {
return (
<Page>
<Section
title={<Text bold align="center"> TimeTable</Text>}>
<ColorSelect
settingsKey="color"
colors={[
{color: "tomato"},
{color: "sandybrown"},
{color: "#FFD700"},
{color: "#ADFF2F"},
{color: "deepskyblue"},
{color: "plum"}
<TextInput
label="PO Lesson"
settingsKey="POLesson"
name="Name"
<TextInput
label="PO Location"
settingsKey="POLocation"
</Section>
</Page>
registerSettingsPage(mySettings);
