edit: 1/31/2019
I think I've been patient waiting for a response... This is appears to be a bug. Can you confirm that it is or isn't? The code can be found here: https://github.com/Elray56/TestCompanion
It transfers styles.css to the companion which accepts the file transfer (pop).
Press up to send the file, press down button to check the status
edit: 1/10/2019
Can I please get some help with this? Can the developer get online and explain how the design between the app and the companion is intended to work? Is this a bug? Do you need more info?
original:1/7/2010
I'm using the new outbox.enqueueFile capability to transfer a file to the companion. It works perfectly except the device still shows the file as enqueued. I can verify that the file transfer worked and the file is on the companion. I assumed that they would "go away" after being successfully transferred to the companion yet the enumerate function lists every file that was transferred. Looking at the files on the simulator, they still exist in the app's outgoing/stage folder.
Where am I going wrong?
Rich
