04-14-2018 09:46
04-14-2018 09:46
Hi,
I keep getting this error, "Error 0 Critical glue error," when I install my analog clockface on my Fitbit Versa. I can see the clock hands working, although they are -90 degrees off, but there is no background; I get a black background.
I don't get any errors when I connect to the simulator instead. and I can see the background in the simulator.
This is how I implemented the background:
<image id="image" width="100%" height="100%" href="hands/HermesStyle.jpg" load="sync"/>
I tried converting the image to png but the same problem occurs.
04-16-2018 10:23 - edited 04-16-2018 10:42
I found out what's wrong.
For some reason, Photoshop saved the image with dimensions of 625x625 pixels.
When I changed the dimensions to 300x300 pixels. Everything worked fine. No errors.
I did not change the svg file. It's still the same.
04-16-2018 04:23
04-16-2018 04:23
Best Answer04-16-2018 10:11
04-16-2018 10:11
Every tag in the svg has an id.
<svg>
<g id="hours" pointer-events="visible" transform="translate(50%,50%)">
<image x="-72" y="-9" width="92" height="18" href="hands/hr_hand.png" />
</g>
<g id="mins" pointer-events="visible" transform="translate(50%,50%)">
<image x="-6" y="-94" width="12" height="115" href="hands/min_hand.png" />
</g>
<g id="secs" pointer-events="visible" transform="translate(50%,50%)">
<image x="-27" y="-104" width="52" height="162" href="hands/sec_hand.png" />
</g>
</svg>
Best Answer04-16-2018 10:15
04-16-2018 10:15
Some of the images don't have an ID.
Best Answer04-16-2018 10:23 - edited 04-16-2018 10:42
03-22-2019 07:39
03-22-2019 07:39
Just want to add my 2 cents and my thanks for pointing this out. I had several images in my watch face that were larger than what the svg width and height settings specified. In the simulator, it did the scaling automatically and worked fine. I thought the image scaling in the simulator and on the watch looked smoother than if I "pre-scaled" the images in Gimp or Paint to the right size, so I deliberately left the images larger than needed. On the watch itself, the images sometimes appeared, and sometimes were dropped. I didn't equate the cryptic "Critical glue error" with this until I read this post. It seemed like the more scaling that was required, the more likely it was to have problems. I thought it was a memory problem, so I spent a lot of time looking for memory leaks. It's really annoying to have an app work perfectly in the simulator and fail completely on the device! I think the svg documentation should state that scaling images on the device is not reliable and can lead to the "Critical glue error".
