Issue extended from this [https://community.fitbit.com/t5/SDK-Development/Import-external-module/m-p/4178893#M11671]
I'm still using the sdk-cli to use the module but when i try to import a module it return me the same error ( Cannot find module '{module name}'
t.default at sim-file:/bootstrap:696,15)
What can i do resolve this?
The module that i'm using was installed with the command npx create-fitbit-app <project-name> [https://dev.fitbit.com/build/guides/command-line-interface/]
I create a repo of my code to resolve the problem and show the code [https://github.com/marcs7/TestCodeFitBitApp]
edit:
Using ES6 format (import from) it retruns this error:
code: UNRESOLVED_IMPORT
watchFiles: path file
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! test@0.1.0 build: `fitbit-build`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the test@0.1.0 build script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
Build failed with code: 1
I think that will not work, to avoid any issue I’m using fetch api and pass data through rest api, when possible. I’m thinking that I will switch to a self made device to avoid the restrictions to this device (Fitbit ionic)
