01-29-2020 05:53
01-29-2020 05:53
Hi,
I'm new to the fitbit development. Where can I find informations for a little more complex gui-settings? I found the fitbit-documentations (i.e. https://dev.fitbit.com/build/guides/design-guidelines/drawing-the-blueprints/) but on this page is not explained how to build this layouts.
I want to build an app that consists of a main single screen and a setting page (access via combo button or slide horizontal or vertical).
Best regards
Kay
Best Answer01-30-2020 12:26
01-30-2020 12:26
Fitbit Studio has a "Settings" template project to get you started. It's fairly minimal, but sends the settings values from the companion to the device.
You can also see lots of sample projects here: https://github.com/Fitbit/ossapps
01-30-2020 12:26
01-30-2020 12:26
01-31-2020 00:38
01-31-2020 00:38
Thank you. The link is helpful.
