06-09-2018 07:53
06-09-2018 07:53
Ok so I am on ios and I would like to have fetch working with a server that has a self signed cert. I added the cert itself under profiles in ios. Still when I call fetch I get "TypeError: Failed to fetch". I tested the code with a non-https server and there it is working fine. Is there anything that I am missing or is there any better way to get some error reporting ?
Thanks,
Lukas
07-01-2018 00:01
07-01-2018 00:01
Hi John, thanks for your reply.
I retried it today and managed to get it working. To make sure other people can avoid running into that problem here is how to do it:
The certificate you install on your phone has to be a CA certificate (as you mentioned). Generate and selfsign this using openssl (If you do not know how: https://datacenteroverlords.com/2012/03/01/creating-your-own-ssl-certificate-authority/)
Generate a cert for your server and make sure it has the correct Common Name set (an ip is also valid)
And then comes the part that created the issue for me: In IOS 10.3 Apple introduced new Certificate Trust settings. After going through the process of installing and trusting the cert as a Profile (in General->Profiles) You have to go too General->About->CertificateTrustSettings. There make sure your CA cert is also trusted there.
If you follow this steps It sould work just fine! =D
(For completeness: insecure plain http requests do also work, although this is NOT advised in any case)
Best Answer06-30-2018 07:43
06-30-2018 07:43
I believe it's ATS on iOS which is blocking this.
With App Transport Security (ATS) fully enabled, the system requires that your app’s HTTP connections use HTTPS and that they satisfy the following security requirements: The X.509 digital server certificate must meet at least one of the following trust requirements: Issued by a certificate authority (CA) whose root certificate is incorporated into the operating system Issued by a trusted root CA and installed by the user or a system administrator.
Best Answer07-01-2018 00:01
07-01-2018 00:01
