The vibration module allows access to some pre-defined elements like "ring", "nudge" etc. Is there a way to gain any further degree of control over what the vibration motor does? For example something like a pulse of 500ms duration?
Hi @SunsetRunner - have a look at SimpleVibrate and it's documentation it may help.
What you can do knowing vibrate length is trigger successive commands or let Alert (continuous vibration) run for a predefined time.
