I need to develop an app for research purposes. I am considering purchasing the Fitbit inspire 3. Is there an SDK that allows me to interact directly with the fitbit inspire 3 through the app I need to develop?
Is Fitbit Inspire 3 supported by API? I would like to at least export user data for experimental purposes and also show it in a webapp. I need to track steps and information from the accelerometer.
@inglukaj- while you can't write trackers apps the historic [post sync] uploaded data is available, probably best to post here Web API forum
This may give you some idea of what is available Web API
Best AnswerSteps you can get (after a delay) from the Web API. Accelerometer you can't get.
I suspect that Inspire 3 is not the right tool for this job.
