Is there a way to reset the Devbridge access? I had changed the system clock on my PC to test certain scenarios. Now Fitbit OS Simulator crashes on open with the following:
"devbridge.connect","params":{"authorization":"<redacted>","uri":"wss://027-v3-api-
I cannot use the OS simulator on this machine any more.
Hmm, thanks for reporting that. It shouldn't be crashing.
on OSX it’s in keychain
on Windows, it’s under “Credentials Manager”
there should be an entry called “fitbit-sim-production”
That was it. I removed the credential from the Manager and everything is back to normal.
Thanks for the solution.
