Once Fitbit Studio is removed where will the OS Simulator be available from, or is it being discontinued too?
Will all the references to the the Fitbit Studio be removed from the Getting Started and other places, otherwise it will be very confusing?
I found this old out-of-date link https://simulator-updates.fitbit.com/download/latest/win
@Gondwana - there are links to Fitbit Studio all over the place. It would be very misleading if they remain.
And it seems Fitbit Studio is the only place where you can get the current OS simulator.
So once Fitbit Studio is removed you can't download the current simulator.
@Gondwana- that page needs to be heavily revised to remove Fitbit Studio references, but it does point to the current OS Simulator but that also points to Fitbit Studio. The old out-of-date link needs updating to point to the latest version.
No mention has been made what is happening to the Simulator when Studio is removed, will it be abandoned too, is there an update for use with CLI?
Best AnswerSim works perfectly with CLI; it's not Studio-specific.
