Looking for a basic tutorial or hints for editing with Fitbit Studio.
I figured out <ctrl-f> does a search. Is there an undo option? Search and replace?
Best AnswerThis is a good question. It's a wonder it hasn't been asked before. After a little digging, I found this (more or less):
Basic Left goCharLeft Right goCharRight Up goLineUp Down goLineDown End goLineEnd Home goLineStartSmart PageUp goPageUp PageDown goPageDown Delete delCharAfter Backspace delCharBefore Shift-Backspace delCharBefore Tab defaultTab Shift-Tab indentAuto Enter newlineAndIndent Insert toggleOverwrite Esc singleSelection PC Ctrl-A selectAll Ctrl-D deleteLine Ctrl-Z undo Shift-Ctrl-Z redo Ctrl-Y redo Ctrl-Home goDocStart Ctrl-End goDocEnd Ctrl-Up goLineUp Ctrl-Down goLineDown Ctrl-Left goGroupLeft Ctrl-Right goGroupRight Alt-Left goLineStart Alt-Right goLineEnd Ctrl-Backspace delGroupBefore Ctrl-Delete delGroupAfter Ctrl-S save Ctrl-F find Ctrl-G findNext Shift-Ctrl-G findPrev Shift-Ctrl-F replace Shift-Ctrl-R replaceAll Ctrl-[ indentLess Ctrl-] indentMore Ctrl-U undoSelection Shift-Ctrl-U redoSelection Alt-U redoSelection emacs Ctrl-F goCharRight Ctrl-B goCharLeft Ctrl-P goLineUp Ctrl-N goLineDown Alt-F goWordRight Alt-B goWordLeft Ctrl-A goLineStart Ctrl-E goLineEnd Ctrl-V goPageDown Shift-Ctrl-V goPageUp Ctrl-D delCharAfter Ctrl-H delCharBefore Alt-D delWordAfter Alt-Backspace delWordBefore Ctrl-K killLine Ctrl-T transposeChars Ctrl-O openLine mac Cmd-A selectAll Cmd-D deleteLine Cmd-Z undo Shift-Cmd-Z redo Cmd-Y redo Cmd-Home goDocStart Cmd-Up goDocStart Cmd-End goDocEnd Cmd-Down goDocEnd Alt-Left goGroupLeft Alt-Right goGroupRight Cmd-Left goLineLeft Cmd-Right goLineRight Alt-Backspace delGroupBefore Ctrl-Alt-Backspace delGroupAfter Alt-Delete delGroupAfter Cmd-S save Cmd-F find Cmd-G findNext Shift-Cmd-G findPrev Cmd-Alt-F replace Shift-Cmd-Alt-F replaceAll Cmd-[ indentLess Cmd-] indentMore Cmd-Backspace delWrappedLineLeft Cmd-Delete delWrappedLineRight Cmd-U undoSelection Shift-Cmd-U redoSelection Ctrl-Up goDocStart Ctrl-Down goDocEnd
It requires a bit of interpretation, and I certainly haven't tested all of it, but what I have tested seems to work.
Methinks something like this would be good to add to the official documentation.
Ctrl+Z for undo - the SDK stores the changes from the current session so repeated Ctrl+Z can take you back to starting code at start. If you exit the session (close the SDK, and see the project list) the current files in the project get saved and Ctrl Z only works on new changes.when you reload the project.
I have not found (or looked for) a S & R -
Ok, I found some general shortcuts that seem to work. But no multiple find and replace option though.
https://www.howtogeek.com/115664/42-text-editing-keyboard-shortcuts-that-work-almost-everywhere/
Thanks for all the info. There are however, Fitbit Studio specific shortcuts, such as ctrl-b... which builds the project. I can't imagine there isn't any documentation on this. What framework is Studio based on? Perhaps that's where we can find the answers.
You can press ? when not focused in the text editor to see some studio specific shortcuts.
CMD / - code comment/uncomment
CMD B - build
CMD R - run
CMD P - command palette
On Windows it's CTRL instead of CMD.
Ok, cool. So CodeMirror supports all kinds of rich editing functionality, such as autocomplete, folding, themes. Doesn't look like much of that is supported in the Fitbit Studio or am I doing it wrong?
Best AnswerI am looking for some very basic Fitbit Studio info
eg -
1) You can not (unfortunately). You have to export it and then reimport it (and change name), see point 2
2) Create an empty project. Unizip the zip file containing the source code and drag and drop the content into your empty project file.
