04-01-2021 13:00
04-01-2021 13:00
Hi everyone!
I've a problem to studio.fitbit.com.
Every clock that I made does go, but .... the only one than not run it's Versa 2, the smartwatch that I have.
How are the extension for made a clock face for Versa 2? Specificaly the index in the resource directory and the file widget, in the same directory.
I tried to search a response online but don't find anything.
Thank you!
04-01-2021 14:56
04-01-2021 14:56
Thank you for visiting the Fitbit Community, @CamillaTofani.
Thanks for the information provided.
I moved your post to SDK Development board because it is more related to the topic.
One of our developers will get in touch with you as soon as possible. Thanks for your patience.
See you around.
Best Answer04-01-2021 17:34
04-01-2021 17:34
This MIGHT help.
Depending on what you're trying to do, you might also need to hand-edit package.json, which you can do by temporarily appending .txt to its filename.
