Hello,
I have to get my local time zone from my companion device (Fitbit still does not include this info in its Date function). The only time I can get the time zone is if there is a settings change. Is there a way to store the last sent time zone, check it against the current one, then send it the tracker if there is a change?
The device can ask the companion what the timezone is using the Messaging API. You can persist that in the companion using local-storage.
https://dev.fitbit.com/build/guides/communications/messaging/
https://dev.fitbit.com/build/reference/companion-api/local-storage/
Best AnswerAny tips on how to get the companion app to activate without opening it? It doesn't seem that having this code helps if I have no way to get it to execute. Other than opening the companion app, is there a way to make it run? The only solution I can come up with is to sync on a too frequent basis.
Thanks.
Just send a message from the device to the companion and the companion will wake if it's sleeping.
