Get text value from Element
ANSWERED
Hi, I'm just implementing a scrolling text element in which the text is dynamically set. I have it all working fine now. But for another feature, I need to get that text from the element (see below). Can anyone help me out? Thanks!
PS. I pulled this exact code from here (changing values as I needed): https://dev.fitbit.com/build/guides/user-interface/svg-components/text/#dynamic-textarea
<svg id="forecast" viewport-fill="fb-red" display="none" class="weatherInfo">
    <use id="marquee" href="#marquee-text" font-size="20" width="41%"
       height="21" fill="white" mode="1" value="50">
       <rect width="100%" height="100%" fill="none" opacity="0.2" />
       <set href="group/text" attributeName="text-buffer" />
       <set href="group/separator" attributeName="width" to="50" />
    </use>
</svg>
1 BEST ANSWER
Accepted Solutions
Do you promise not to laugh at me?
marqueeEl.getElementById('group/text').text
I suspect that Fitbit implemented a setter for marquee.text, but not a getter.
Of course, if you're writing to .text, you could just keep track of what you're writing. 🙂
Peter McLennan
Gondwana Software
5 REPLIES 5
I haven't tried it, but it might be something like
let marqueeEl = document.getElementById('marquee');
let text = marqueeEl.text;
Peter McLennan
Gondwana Software
Sadly, I've tried this already and it just returns nothing.. I'm thinking it has something to do with the HTML tags, but I'm not sure what since I'm setting the text using:
marqueeEl.text = "My data string";
And it works as intended, just not able to retrieve the text
Peter McLennan
Gondwana Software
I laugh at no one who can provide me with a working piece of code! Thank you!!
Peter McLennan
Gondwana Software
