I'm doing quite a lot of efforts in the art of coding and I'm now learning how to make external functions that help to keep the code clean.
However i'm having some problems to create a module for my weather script; I guess I'm having issues about dealing with the concept companion/apps exchange of information.
The entire experimental clockface with weather information is hosted here
And the relevant app and companion scripts are below:
App Index.js
import clock from "clock";
import document from "document";
import { units } from "user-settings";
import * as util from "../common/utils";
import { battery } from "power";
// Import the messaging module
import * as messaging from "messaging";
// Import measure units
const measureUnitsPref = units.distance;
// Set clock granularity (minutes or seconds)
clock.granularity = "minutes";
// Get a handle on the <text> element
const timeHandle = document.getElementById("timeLabel");
const temperatureHandle = document.getElementById("temperatureLabel");
const weatherConditionsHandle = document.getElementById("weatherConditionsLabel");
const locationHandle = document.getElementById("locationLabel");
const dateHandle = document.getElementById("dateLabel");
const batteryHandle = document.getElementById("batteryLabel");
// Update the <text> element every tick with the current time
clock.ontick = (evt) => {
let today = evt.date;
timeHandle.text = util.timeFunction(today);
dateHandle.text = util.dateFunction(today);
batteryHandle.text = 'Battery: '+ battery.chargeLevel + ' %'; // Battery Measurement
// Weather module
// Request weather data from the companion
function fetchWeather() {
if (messaging.peerSocket.readyState === messaging.peerSocket.OPEN) {
// Send a command to the companion
messaging.peerSocket.send({
command: 'weather'
// Display the weather data received from the companion
weatherConditionsHandle.text =
function processWeatherData(data) {
if (measureUnitsPref === "us") {
temperatureHandle.text = Math.round((data.temperature * 9 / 5) +32) + " °F";
else {
temperatureHandle.text = Math.round(data.temperature) + " °C";
weatherConditionsHandle.text = data.weatherConditions;
// locationHandle.text = data.location;
// Listen for the onopen event
messaging.peerSocket.onopen = function() {
// Fetch weather when the connection opens
fetchWeather();
// Listen for messages from the companion
messaging.peerSocket.onmessage = function(evt) {
if (evt.data) {
processWeatherData(evt.data);
// Listen for the onerror event
messaging.peerSocket.onerror = function(err) {
// Handle any errors
console.log("Connection error: " + err.code + " - " + err.message);
setInterval(fetchWeather, 30 * 1000 * 60);Companion index.js
import { geolocation } from "geolocation";
var API_KEY = "MY APY KEY";
// Fetch the weather from OpenWeather
function queryOpenWeather() {
geolocation.getCurrentPosition(locationSuccess, locationError);
function locationSuccess(position) {
var lat = position.coords.latitude;
var long = position.coords.longitude;
var linkApi = "https://api.openweathermap.org/data/2.5/weather?lat=" + lat + "&lon=" + long + "&units=metric" + "&APPID=" + API_KEY;
fetch(linkApi)
.then(function (response) {
response.json()
.then(function(data) {
// We just want some data
var weather = {
temperature: data.main.temp, weatherConditions: data.weather[0].main, location: data["name"]
// Send the weather data to the device
returnWeatherData(weather);
.catch(function (err) {
console.log("Error fetching weather: " + err);
function locationError(error) {
console.log("Error: " + error.code,
"Message: " + error.message);
function returnWeatherData(data) {
// Send a command to the device
messaging.peerSocket.send(data);
} else {
console.log("Error: Connection is not open");
// Listen for messages from the device
if (evt.data && evt.data.command == "weather") {
// The device requested weather data
queryOpenWeather();
}I would really appreciate your help as I'm a little stuck. Thanks!
How about something like this? It's incomplete and untested, but should give you an idea.
export default class Weather {
conditions;
constructor(options) {
this.options = options;
fetchWeather(lat, long) {
var linkApi = `https://api.openweathermap.org/data/2.5/weather?lat=${lat}&lon=${long}&units=metric&APPID=${API_KEY}`;
fetch(linkApi)
.then((response) => {
response.json();
.then((data) => {
this.conditions = {
if (this.callback && typeof this.callback == "function") {
this.callback();
this.fetchWeather(position.coords.latitude, position.coords.longitude);
getWeather(callback) {
this.callback = callback;
geolocation.getCurrentPosition(this.locationSuccess, this.locationError);
import Weather from "./weather";
let weather = new Weather({
sample: "setting"
function callback() {
console.log(JSON.stringify(weather.conditions));
weather.getWeather(callback);
Thanks a lot @JonFitbit, I will try to give it a go over the weekend, this week RL job is crazy and in the evening I really want to do everything (aka sleeping) but coding ![]()
