07-28-2018 19:41
07-28-2018 19:41
I have the following code defining a gradientRect in my SVG code:
<gradientRect x="0" y="0" width="100%" height="100%"
id="grBurst"
gradient-type="radial"
gradient-x1="50%" gradient-y1="50%"
gradient-x2="50%+150" gradient-y2="50%+150"
gradient-color1="magenta"
gradient-color2="blue"
/>This is close to a cut and paste from the guide. I can add:
visibility="hidden"
in the code and it works wonderfully. The trouble is I can't find a way to do it in JS. I've tried:
and probably half a dozen other variations. Each of these will either display an error message or do nothing. Is there a way to do it? Is there a way I could have learned how to do it myself?
Best Answer07-28-2018 19:49
07-28-2018 19:49
.style.display = "none" should do it. Have you correctly set the value of grBurst in your javascript?
Best Answer07-29-2018 05:29
07-29-2018 05:29
I set grBurst with:
const grBurst = document.getElementById("grBurst");
This is the same way I define all of my other elements.
The .style.display = "none" statement returns "Unhandled TypeError: Cannot assign property 'display' of undefined."
Best Answer07-29-2018 07:40
07-29-2018 07:40
That's a weird one. You could just wrap it in an <svg id="blah">, then hide that svg element.
