I have run into an issue with the AdditiveList/TextInput autocomplete function in the settings. I want to populate the autocomplete from a web API (similar to the BART example, but with live data from the API I am querying), but fetch() (the only supported web-accessing API) is an asynchronous system, as was XHR before it.
Unfortunately, the onAutocomplete field requires that the function returns an array. However, I can't work out how to wait for the request to complete from within the callback in fetch().then(); Does anybody have any ideas on how I can complete this?
There has been a previous question over a year ago on this, but that went ignored, so whilst this is technically a dupe, there has been no answer that I can find: https://community.fitbit.com/t5/SDK-Development/Settings-google-places-fetch/m-p/2596118#M3348
My code:
settings/index.jsx:
import { search } from "../common/apiHelper.js";
function mySettings(props) {
return (
<Page>
<Section
title={<Text bold align="center">TfL Buses App Settings</Text>}>
<AdditiveList
title="Select up to 5 bus stops to check"
settingsKey="favourite_stops"
maxItems="5"
addAction={
<TextInput
title="Add a new bus stop"
label="New Stop"
placeholder="Type something"
action="Add Stop"
onAutocomplete={stopSearch}
</Section>
</Page>
function stopSearch(value) {
search(value, function(jsonReply){
console.log("stopSearch->jsonReply: " + JSON.stringify(jsonReply));
results = jsonReply.matches;
for (result in results){
registerSettingsPage(mySettings);
common/apiHelper.js:
(there are more exports for other API calls, but search() is the only one used in the settings)
const BASE_URL = "<url_of_api>";
function get(endpoint, queryString, callback){
var url= BASE_URL;
url += endpoint;
url += "?";
url += queryString;
fetch(url).then(function(response){
if (response.ok){
response.json().then(callback)
else {
callback({error: true, statusCode: response.status, statusText: response.statusText, body: response.body});
export function search(query, callback){
get("/search", "searchTerm=" + query, function(jsonReply){
if (jsonReply.error === true){
// log error for debugger and ignore callback
console.log(JSON.stringify(jsonReply));
else {
// success - return data to callback
callback(jsonReply);
