You've gotta get that to 'connected'. Make sure the watch's wifi network is correct and that it can sync. If wifi signal is weak, might need to move closer to access point.
Best AnswerStudio: select Ionic from device drop-down (from memory).
CLI: 'connect device' or just close simulator.
You might need a companion device, depending on your code.
