03-10-2023
18:11
17:55
AndreaFitbit
03-10-2023
18:11
17:55
AndreaFitbit
for some reason when I change the version to sdk 4.2 and the device for versa 2 it won’t work
Moderator edit: format.
Best Answer03-12-2023 08:00
03-12-2023 08:00
Hi people, I figured it out, you have to change some file names and some file types and then it works, thanks for helping though
Best Answer03-10-2023 18:26
03-10-2023 18:26
Studio or CLI?
If CLI, did you npm -i or equivalent?
Best Answer03-10-2023 22:57 - edited 03-10-2023 22:57
Hi, @1545 - you can only use SDK 4.3 in Fitbit Studio as it has no backward compatibility so you will be forced to use CLI, even so it may not be possible to get full backward compatibility as the code produced, if you can get it working, may not be fully compatible with the original SDK 4.2.
However if your Versa 2 is at the latest firmware level you can use SDK 4.3.
Also do you try using the OS simulator to compare how your clock face works.
Best Answer03-11-2023 06:21
03-11-2023 06:21
what is CLI as I am new to Fitbit studio and I don’t really understand it
Best Answer03-11-2023 06:52
03-11-2023 06:52
Also my Fitbit doesn’t have the latest firmware, should I install it?
Best Answer03-11-2023 07:18
03-11-2023 07:18
@1545 - Fitbit Studio is being discontinued in a week or so.
If your clock face only works in the OS Simulator, which you can download from the Studio menu, it maens you need to upgrade the firmware on your watch.
It can happen at initial setup of a watch it doesn't install the latest version.
2 solutions. Wait a few days till it becomes available, or factory reset it from the watch settings menu and start setup again.
CLI is an old Command Line Interface.
Best Answer03-11-2023 11:10
03-11-2023 11:10
Documentation on CLI is here.
To run SDK 4.2, your watch will need firmware of 35.71.6.12 or later, I think.
To run SDK 4.3, your watch will need firmware of 35.72.1.15 or later, I think.
Best Answer03-11-2023 11:46
03-11-2023 11:46
Release history documentation can be found here
03-12-2023 08:00
03-12-2023 08:00
Best Answer03-13-2023 10:08
03-13-2023 10:08
Best Answer03-13-2023 12:49
03-13-2023 13:04
03-13-2023 13:04
you must change the file types for it to work, please stop posing here as I am getting emails and I don’t like it
